I am having a real hard time trying to get into reverse. I push it all the way over, and try to go up, but it doesn't want to go. Usually if I let off the clutch a bit it will grind into gear, but that is not good. My other alternantive is to get back into neutral, move the shifter around for a bit, then try it again, and it will go in just fine. I don't like this at all. All I have done is a Steeda Short Shifter, is this causing my problems? It sounds more like a synchro (sp?) problem than a SS problem. Can some one help me out, please?
