quite a bit of work. you need the IB5, the clutch pedal, the shifter and linkage. i think you might need your ecu flashed. alot of time. and i know im missing alot
Not Special Enough
You can use the automatic ECU. It will just trip a fault for the missing shift solenoids. in addition to what was listed, you'll need the shift tower, upper transmission mount, half shafts, flywheel, clutch, pressure plate, manual trans starter, and clutch line.
..and in addition to what txfo said, you will need the brake/clutch resevior as well but you will be able to keep the axles, they will swap.
Not Special Enough
IB5 and auto shafts are the same?
odd.
I was going to mention the fluid resevoir but I thought maybe it was the same one but with a block off for the clutch line.
haha..no they are not. Mtx-75 and auto shafts are the same.
