Well, time to blow the dust off this post...and this account. Looking at my posts, last login date was 2016!! How time flies. I'll try to be thorough, but I don't have all the photos easily accessible right now, but here's the story of how this car got back on the road, and is still going today!
After a few changing of hands, I acquired the car in January 2019. The engine was dead, but we didn't know just quite how dead it was. As you'll find out later...it was real dead. The engine was low on compression on all 4 cylinders, so we initially thought it was a timing issue. With the engine still in the car, we used the Massive timing bar to verify that the engine was still in time, and it was spot on, so that was ruled out. I had brought a borescope that day, we used it to inspect the pistons, and it looked like Cylinder #3 had a crack in it.
Out came the engine to do some digging.
I left the car at my friends shop and took the engine home with me to tear it down in my spare time after work and on weekends. I had never taken an engine apart this far before, so this was a learning experience in itself. At the time, I didn't have an engine stand, and had to make do with what I had.
A couple weeks went by, I picked up an engine stand, and continued tearing the engine down. I was having trouble getting that awesome lightweight flywheel off because I couldn't get enough heat into the bolts. However, after lots of patience and the purchase of a big ass electric impact, the bolts finally came out. Next came the oil pan, then the windage tray, and finally the main caps and crank...and ooooooh boy.
The main bearings were all spun, the rod bearings were all spun, and...well, I was right about the pistons being cracked. Just...not in the spots it looked like on the borescope. All 4 pistons had cracked ringlands: all in the same section and on the same side. Yikes....well, this was already going to be an expensive build, so I wasn't terribly concerned about it. However, the damaged pistons did a number on the cylinder walls, and I decided it would make more sense to start rebuilding on a block that wasn't all scored up. Time to source a new engine.
Well, since I'm this far, I might as well keep going...is what I told myself.
I sent the head off to Total Engines in the Twin Cities to have the head gone through, and oh man did they come through in a gigantic way. 3 angle valve job, port and polish, and they mic'd all the valves, put new valve seals in, and set the lash on it. It's truly a work of art.
The story continues below, we're only to fall of 2019.
