Taken from www.steedafocus.com
Steeda Tri-Ax/F Short Throw Shifter
Shift your Focus faster and easier with Steeda's Tri-Ax/F short throw shifter. The Tri-Ax/F is more than just a short handle. We re-engineered the entire shift mechanism with an improved pivot ratio so you can enjoy faster shifts without having to bend down to reach the shift knob. The shift knob is located in a more comfortable position than the too-tall factory shifter, without being too-short like other "short-throw" shifters
All Tri-ax shifters also include Steeda's patent-pending Shift Assist, which improves spring tension to make quick shifts from second to third gear easier. This simple device lets you powershift with confidence, knowing you will find the right gear every time.
The Tri-Ax/F is manufactured with heavy duty parts to withstand abuse, including a CNC machined steel shaft and billet aluminum reverse lock. Installation can be done with basic hand tools by the do-it-yourselfer in two hours. The Tri-Ax/F fits all 2.0L Zetec Focus is equipped with the MTX75 five-speed transmission.
