1 - 20 of 46 Posts
Richnev
· Registered
Discussion starter · #1 ·
and here is a pic of my engine before comeing to Florida which pic of the engine do you like?
what do you think so far?
I still need to get the exhaust all worked out
then it is transmission and suspension
please post comments both positive and negative
Many Thanks go out to Tekin (for helping clean my engine bay up and getting everything running right) and for Sam at Coastal Dyno for tuning my car for me
Next on the list is battery relocation, new alum. coolant tanks, down pipe, and try to get those 90degree intake temps even lower.
it is using a south florida performance manifold with a tial 38mm waste gate.
Discussion starter · #5 ·
you can see what the Florida humidity did to it compared to the El Paso 7% humidity lol
Got any close ups of the manifold/turbo? Looks good,
Scott
Discussion starter · #12 ·
oh but mine is innercooled
that shiny thing is a barrel liguid/air innercooler
Discussion starter · #14 ·
was going to do it after work but it got dark quickly, will have to do it tomorrow
Discussion starter · #16 ·
Looks like a good setup without spending too much cash. What turbo is being used? How much of an IAT and pressure drop is there with that intercooler?
It is a garrett T3/T4 turbo
no preasure drop, and IAT in the mid 90's with mid 70ambient air temps
I have a Blitz boost controller and a diablo revolution chip tuned for 8 lbs and 10 lbs of boost the numbers in my sig are for 8lbs of boost
*edit Oh yeah the motor is stock except for bigger 80mm Maf and 42lb injectors
um thats all been fixed...... its staying returnless.
car is running alot better than it was.
1 - 20 of 46 Posts
