1 - 20 of 21 Posts
Stay FAR away from that kit! It's useless ebay Chinese knockoff junk quality.
If you are looking for a good, reliable turbo kit for a street/daily driven car, I recommend the FSWerks turbo kit.
If you are looking for a turbo kit with potential for tons of power, I recommend the Top Speed turbo kit.
Bottom line, if it's a turbo kit listed for a Ford Focus and it's not from FSWerks nor Top Speed Performance, it's probably junk.
Thank you i kinda figured that do u know of any other tubo kits that wont cost me 4000
You won't get much cheaper than what Vik posted above unless you get lucky piecing together and building your own kit. In the end, it really comes down to tuning. If you can buy an XCal and Pro Racer software and tune yourself you'll save some money, but if not, you'll be around what Vik posted after you pay for a competent tuner.
If you have a Zetec our FSWERKS intercoolered turbo kit retails for $3,295
Look here...
http://fswerks.com/zetec-turbocharger.htm
Thanks,
Vik
Very good kit on a stock motor. If you ever want to go to a full motor build to make high numbers then Top Speed has those kinda turbo kits. There are a few that are pushing past the 350 and even the 400whp mark aka the big boys.
what kinda hp and tq will i expect to c from the two kits. Could i make 210fwhp cuz thats my goal
210whp at 8psi without really even stressing the motor. There are plenty of people here that are pushing 220+whp on the stock motor. I'm putting down 260+whp on a stock Duratec. Also, whp doesn't really kill motors, torque does. You can make 310whp on the stock engine and it run just fine so long as the torque doesn't exceed ~250wtq as that's pushing the safe limit.
11psi
That number of 260whp is also an estimate as the tune isn't dialed in yet for my most recent mods. I'm expecting 275+whp once I actually hit the dyno.
Better make some more to get your old title of stock block back :rock:
why cant the fswerks turbo be carb legel :[ cant play in ca :[
LOTS of people play in Cali. You just have to be willing to change back to stock every time you need to smog. I've heard of someone passing the sniffer with the FSW kit and their stealth exhaust. CARB is way to expensive to try to do, especially for a turbo kit. It would drive the price of the kit through the roof.
1 - 20 of 21 Posts
