1 - 8 of 8 Posts
ok im trying to pull out my old broken atx tranny but i can get the driver's side CVU boot off... the damn thing is in the way.... please help !!!
i have always had to pop the ball joint out an swing the strut outa the way. if you need to you can tap the cv joint outa the tranny. but becarful tapping it out
Discussion Starter · #3 ·
i got everything outta the way but the cup in the transmission will not come out, i removed the CVU joint but that piece is sticking out just far enough, that i cant get the tranny down
you will have to drop the black sub frame. but becareful becuz you can loose your rack (steering) and then your really F***ed. that help also?
Discussion Starter · #5 ·
does that mean that the piece doesnt come out, because i gotta have that piece to put the CVU joint back in
ok i dont completely understand what has happened. did you break the cv axle itself? and the boot is still in the tranny? or what. is there anyway you can snap a quick pic?
Discussion Starter · #7 ·
no digital camera here. did get the joint removed from the boot though.
1 - 8 of 8 Posts
