1 - 9 of 9 Posts
· Registered
Who has had experience and success puting jackstands under the Focus after jacking the car from the normal jacking points?
After jacking the car, that location is not available for a jackstand. I tried the front A arm mount and it appeared to be bending!
Any experience or insights.
Thanks,
· Registered
There are a couple of points. About 1 foot behind the front A-arm mount, there is an open spot about 10 inches in diameter that I have lifted the car up several times using a 2-ton lift. Look for parts of the frame, as well; this is more tricky, since if you are not careful you can hook onto the ground effects inadvertently.
Andrew
· Registered
^^^What he said.
Or you could look in your OWNERS MANUAL where it shows you PICTURES of the jacking points.
· Registered
What? Mine doesnt have anything like that.
It has a pic of the car from the side, with arrows pointing and closeups of the notches in the frame rails (behind the front wheels and in front of the rear wheels).
If your manual is that weird, sorry for the extreme sarcasm before.
· Registered
Discussion Starter · #7 ·
Jimmy,
Just how does one place a jackstand at the same location that the jack is???????? Hello.
Read my thread again please.
As an aside, the SVT has a body panel/molding that obscures the notches on the rocker panel seam. One has to measure the 6in and 15 in from the front and rear wheel well opening to be "exact".
· Registered
For the front of the car I use two points on the front cross member, if you look under the car towards the outer ends of the cross member you will see a raised area anout 1.5" wide and about 3" long. These pads make a perfect resting place for jack stands, I use these all the time and they work perfect. For the rear, I use the cross tube that runs between the lower control arm pivot points, the ends of the cross tubes have a shightly upward bend on either end but if you place your jack stands there at the end just before the upward bend it works great.
1 - 9 of 9 Posts
