1 - 20 of 49 Posts
Check it out:
http://www.focussport.com/images/Randy/FSturboZX3_JetFest_NASA.WMV
There is a LOT of wind noise. You probably should turn the volume almost all the way down or completely down. Or what I did was take out some of the higher frequencies if you have an EQ that you can adjust. Sorry about that. :eek:
If you are feeling kind of impatient, most of the action starts at 2 minutes into the video.
This was a pretty hot session, though. See what ya think. :thumbup:
Here is the youtube version if you can't or don't want to wait for the download/buffering on our site:
http://www.youtube.com/watch?v=s1Zk4VCEgvo
OK I'll be honest... my butthole is puckered pretty tight, and I'm just watching a video!
Serious driving skill right there.
that video is sweet...its awsome seeing that Speedometer needle pegged bareley getting onto that straight aways. :eek: I bet alot of people went home with their tails between their legs getting EMBARASSED by a Focus that you could build for less than $25k including the car!!! Once again...VERY nice work Guys!! :thumbup:
Super Moderator
Just wow Randy.. I would be on the lookout for people talking about the car on other boards bitching about how they were passed by an egg. ;) LONG LIVE FOCUSSPORT!!! :bow: :bow: :bow: :bow:
Could you give us a mod list/specs besides the motor? I got a chance to check out the car, but not in super great detail
suspension
brakes
tires
wheels
camber settings
etc.
overcooked 3 a couple times, and still faster through 4 than I was. Unbelieveable.
Discussion Starter #15
The non power related set up at the track:
Standard H&R coilovers
Stock front brakes w/ cross drilled rotors and Hawk Blue pads
Stock rear drum brakes :lol:
Kuhmo Ecsta V710 225/50/15 tires on OZ Ultraleggera 15x7 wheels
FocusSport racing camber plates with about 3 degrees of negative camber
Viksport custom roll cage
I can't recall the sway bar set up right now, I'll look later.
That is pretty much what I figured. I noticed the stock brakes before I saw the car passing vettes in the oval...took me about 1.5 seconds to moisten the drawers. The stock brakes aren't half bad.
I change diapers now
You were pulling 160mph down with factory size soap dishes?
I don't care if they have Blues on them or not, ftlog put the SVT kit on it(minimum) w/ blues.
They'll fit under the UL's.
FocusSportTECH said:
By the way if people were wondering the High Boost Button worked like so...
-14psi & ~310whp w/o button being used
-20psi & ~365whp w/ button being used
Dynoed using 91 octane.
Thanks,
Vik
From a couple threads down
1 - 20 of 49 Posts
