I just ran it up to the opening, when you're driving, it will get the air it needs, and when you're sitting still, it should pull air from the front - much better than how the Volant does it alone. Since the hose itself is bendable, though, you could squeeze it wherever you want I suppose, I was going for the least kinks and most direct air flow (while keeping the diameter a full 3 inches).
hypocrisyB, I haven't done the snorkel mod yet, but my idea is to pull the plastic end off (the part that would fit into the airbox), then use this flexible air intake hose to attach to both ends (the snorkel hose and the bottom of the Volant). I might have to get a piece of 3 inch tube about an inch long to slip into the SVT hose and provide something for the new hose to clamp to.
[ 09-02-2002: Message edited by: orndog ]</p>
