1 - 3 of 3 Posts
Not Special Enough
im still having my VSS problem. The speedometer drops off and the radio gets softer (AVC) Its intermittant so it makes me think bad wire or connection. In researching the problem I have been told about a speed control module. Where is that located? also, is that only on cruise control equiped models? I'm beginning to suspect the PCM is trash. which is awesome since I work where they are built and I know how the "quality" is.
Double-Wide Pride!!!
do you know if you might have a code 320? I was looking at the dtc codes and thought that might be part of the problem... I'm probably wrong but, hey theres a slim chance...
Not Special Enough
Discussion Starter · #3 ·
I havent gotten any codes yet. which is why Im pretty sure its the output on the PCM, or a break in that wire. If it was the sensor or sensor wire, I would expect a VSS intermitent code.
1 - 3 of 3 Posts
