1 - 9 of 9 Posts
i have the Mitsubishi TE04H turbo, and ever since we installed it the wastegate is supposed to fully open 6psi (this is w/o a mbc), but the psi keeps going.. when i get on it in 1st gear it goes to 5 psi then i shift, 2nd/3rd gear boosts to 5 then once i reach high rpm's it keeps going like it spikes to 13psi, yes i have fuel management and i do not hear detonation.. could it be the actuator?
id make sure there no cracks in the exaust side of the turbo. there supposedly known to crack. if u have the moeny get a auto boost controller. should stop the creep.
Need more info
What type of wastegate
What kit is it
Tom
It's your kit... didn't u know?
Some porting will help eliminate the creep....but an MBC may be a good solution also.
ive had alot of friends with dsm's that had boostcreep , iam not quite sure what the common fix is , but the internal mitsubishi wastegates suck.
It could be a boost leak. My IAC valve leaked pressure out as fast as I could put it in (tested w/ an airhose hooked to the compressor side of the turbo) before I JB-welded around the crimped part of it. Up until that point I had boost creep as well.
L8r
Brad
1 - 9 of 9 Posts
