i can beat or hang with most of the car that i have raced. but a lot of them will pass me after 90mph intill i getup to around 115-120mph then i start to catch up. what can i do to increase my accleration at high speeds.
Cams alone won't do it. You need a high-flow cat, a better intake (Ice-Man perhaps?), replace the flex-pipe and get a good cat-back system first. Then I'd go with internals like crower cams and some cam gears.
I will guarantee you that full blown exhaust mods will not accomplish as much as a set of good aggressive camshafts. It doesnt free up horsepower, it makes it!
You can get the Crower cams for $280 in the groupbuy.
The exhaust and intake mods mentioned above would cost nearly $1000 dollars.
Remember were running around in a 2 liter 4's, freeing up restriction in our case isnt like putting straigth pipes on a 1/2 ton.
Fully build your motor.....i.e. Get some nasty cams....and some JE pistons and bump compression...blueprint and balanced would help too....
On a side note...How is the Hiper exhaust workin for you? How does it sound? I thought about gettin one...just wanted to hear some opinions before I make my decision...Im stuck between the HKS or the Thermal....or possibly the Tanabe
johns i have had the exaust for 2 months and i love it. it has a great low tone not ricie at all. the only problem is the angle that it comes out the back of the car it burned a spot in my bumper but other than that it only took about 30 min to install the hard part is getting the old exaust off the car
