How different is C1 form C170?
the front subframe is based on the C170 except the subframe has voided bushing where it mounts to the body
The rear Subframe carries over C170's geometry But uses a lighter more struturally efficent subframe design, the mounts are not rubberized.
The biggest improvemant is the Structure, although it is only 10% stiffer it is far more crash worthy, The use of stronger steel in every part f the body, the most impressive piece is the Fron door cross beam, made of extra high strength steel, at the top of the door to offer the absolute best protection to the driver in colissions with higher riding Trucks, plaus the lower door baeam ijn the front door, in the rear the reinforced C-pillar offers side protection. For a safer vehicle even without th avialble Side thorax airbags and Side curtain air bags.
the structural improvements Would cause the majority of the retooling for Ford. but offer the greatest possible improvement in saftey.
In both side impact and frontal collisions the improvements would be most notable.
