1 - 3 of 3 Posts
On my SPI Autotragic , i have ;
- Diablo Chip
- Magnaflow Exhaust
- AEM CAI
- BDR TB ( next week )
What is the next step for more HP ??? I look toward escort-Focus cams.... How many HP i can expect from this cam....
1C1C68C 260/268 dur-.429/.446 lift (MUST use our valve springs and retainers). Good for mild – moderate motor with automatic trans or standard shift. Smooth idle. Pulls good from 2,500 thru 6,000 rpm. Excellent fuel economy. You MUST use new lifters and follow proper break in proceedures with this cam.
Do you have other ideas ????
Not Special Enough
If you are gonna get a cam, get the whole package. you will need the adjustable cam gear. while you have the head off, get it ported and polished, triple angle valve job, you may even consider raising the compression a hair. next big step is P&P on all manifolds.
maybe an UDP?? or complete your exhaust. you know, headers, high flow cat, flex pipe. or race header & flex pipe.
1 - 3 of 3 Posts
