1 - 12 of 12 Posts
I have the mods listed in my signature and im wondering what to do next.
any suggestions?
MAFS or a catback maybe?
<font size="2" face="Verdana, Arial">already got a catback exhaust. Borla
i was thinkin of mafs, what is the diff bewteen stock and a new one
high flow cat and flexpipe to complete the exhaust mods and then a 70MM mafs and bigger fuel injectors...24/lb does nicely
would a mafs work with an Iceman CAI?
I'd go with a flexpipe to put between the header and catback and a UDP. Then cams with gears.
you can always try reducing weight to get better 1/4 mile times.
start by getting rid of all that heavy stereo equipment
Since you have changed the entire adynamics of the intake and exhaust, get adjustable cam gears and have them tuned in on a dyno. Nuf said!
Do the flexpipe just to complete the exhaust.
[ 03-12-2003, 08:56 AM: Message edited by: myFordPerformance.com ]
do the diablo chip. it will help out alittle with all the other mods you will pick up some noticable power. not alot mind you but you will tell a difference.
Well after intake header and exhaust i like to think that the underdrive pulley and cam gears are the next step. Then cams/headwork. Dont bother with a larger mass airflow sensor, you're not putting enough down for that to be a restriction yet. Save your money for better things. Make sure you've got a flex pipe to mate that header and exhaust too.
1 - 12 of 12 Posts
