1 - 2 of 2 Posts
Hello, I own a focus mk1 2003 car. What should be the tps values for the vehicle. My value is off and 1.07 volts on, 4.71 volts this value is not good I guess how do I fix this value without buying parts. And what is the resistance of the idle valve.
TPS about right. They work best slightly under one volt at dead warm idle, .9ish is fine, let the wide open number fall where it will and over 4 volts.
Resistance in IAC is really not going to help much, as a variable number will simply dither the solenoid slightly different. Most IACs get changed for nothing to begin with.
1 - 2 of 2 Posts
