1 - 19 of 19 Posts
can I get a reply if anyone is having a problem with wheel hop. My freind is making a part for my car that he thinks will eliminate wheel hop. He made the same part for his Rx7, an Eclipse, and a Tiburan. He also sells his fix for those cars, and after testing on my car is thinking about selling it.
Super Moderator
Motor mount solved my problems. But I don't know what your HP and TQ is.
<font size="2" face="Verdana, Arial">thats cause you dont know what real wheel hop is like
double the torque you have at the wheel, and its a different story
But my tires spin so fast, they have no time to hop
Super Moderator
Yeah yeah. Who cares. Answer the mans question then!
yeah I'm still dealing with wheel hop too. Let me know how this "Thing" your friend is building works out, I may be interested in one.
hmmm i dont have a big problem with wheel hop mabey my TQ isant that high (140lbs-apx) but with axenies i grip fine droping it at 3 oor easying off the clutch i grip fine
some of you guys should try slicks or some searious street/strip tire (azenies) they realy work but i mean in nazthugs case he has ALOT of power and he is right there is so much spin there isant time for hop
the way naz makes it sound... he's got so much power that his rims spin, but not his tires.
think about it for a sec and you'll get it!
Better Dampers will help w/ wheel-hop.
I had a little bit.
The Motor mount helped it Alot.
I got the Azenis, and had too much traction for anything but "GO".
I got a Diablo Chip, then my Azenis got worn, and have lost traction, so they fight a bit for grip at WOT off the line. They are JUST grippy enough, w/ my power being more than it used to be, that I now have some grip-hop-spin-grip-hop-spin....
I think I'll just be driving around it until I get new tires, and then someday, better dampers.
I have a lot of wheel hop-is your motor mount an upgrade or replacement of a worn out one? I've seen the one advertised here on the Jet-is that the one you installed? I have Kumho 17" tires and 38000miles on the car.
2000 ZX3 jrsc, TB, MAFS, JBA, Random Tech, MBRP, Volant, Superchip
I'm interested, I got a bad hop problem with the drag radials
<font size="2" face="Verdana, Arial">I don't recommend the one in the banner. I support FJ sponsors, but the one in the Ad is unnecessary unless you've BROKEN the factory one.
What we're talking about is the Bushings in that mount. I recommend the Prothane kit from TonyD at NewEdgePerformance.com. It's the SAME thing, except it's Just the Poly-U bushings for about 20 bucks. You re-use the metal that came on the car.
If anyone tries this swap, and has any questions, PM me or post a thread.
Discussion Starter #12
I was having a problem with wheel hop during every day driving, the polyurethane motor mounts are probably the best post-turbo mod Ive done. This "Thing", is just another motor mount. I am looking at having installed at the top left corner of the engine where the lift hook is, and connect it either to the firewall or the strut tower. Like I said its pretty much another motor mount.
<font size="2" face="Verdana, Arial">hehe
Super Moderator
I honestly think that the Prothane mount ranks up there as one of my favorite budget mods.
I haven't hit the track in awhile so I don't know if my dampers are the cause of mine now. (they are shot)
<font size="2" face="Verdana, Arial">Exactly! I couldn't agree more!
Originally posted by MattHarrell:
I've had wicked wheel hop ever since I replaced my stock Firehawk GTA-02's with Falken Ziex ZE-512's. I'll just have to get that turbo charger!
<font size="2" face="Verdana, Arial">The tire change brought the wheel-hop because you've got more traction now.
The above is true. The more I wore off the tires,
the less hop I got. Wheel spin & hop is wasted
power, even if it looks cool at the stoplight.
Try it at the track. I'll bet you save 1/2 a second by leaving at half throttle and letting the tires "hook" than smoking the hell out of them. I got my doors blown off by a 5.7L Jeep
running in AWD. His 60 ft was 1.95, mine was
2.39. Gave him a 44/100ths head start but our
mph's were close (his 90/mine 87.5); he ran a 14.7 to my 16.0. You don't just lose it at the line, you lose it through 1st & 2nd even though
you don't hear the tell-tale screaching.
1 - 19 of 19 Posts
