1 - 7 of 7 Posts
So Chris (airforcefocus) and I spent an ungodly amount of time trying to find this. pin 47, pin 48, each of the three wires coming from the coil pack. WHERE IS IT?!?! How do I insert the wire into ECU? Is there any other place to find the damn thing???
It looks like you're looking for the wrong one... if you have SPI, zetec, motor 2002 the tach pins are 52 and 26 for pin 52 (blak green .75) and for pin 26 (Blak orange .75) you just need one.
Just go to radio shack and buy some butt connector for 16-14 gauge wire.
Discussion Starter · #6 ·
I just RETRIED pin 47 and that does not give me signal. I will try 52 and 48, and then after that, Im going to try the Green wire coming off the coil
EDIT/UPDATE: With the wire in pin 52 the car wouldn't even start.
1 - 7 of 7 Posts
