....i need some help from you guys.....i started to install a set of 5-point g-force harnesses today......not really sure where the best spot is to attach the lap belt.....i started with the passanger side.......i removed the seat and attached the left side of the belt over the factory latch......for the right side i attached it at over the factory location for the front of the "seat belt loop" on the floor......seems to hit the loop.....are you guys mounting them there?.......if so are you using some kind of spacers to move it out from the loop some?..........also, where is a good place to mount the sub belt?.........thanks guys........
.....30+ views and no-one can help?........is rapping the belt around the standard loop okay?........
