113k
That's pretty sucky...I know that certain intakes can void a warranty, but not an exhaust. Any catback exhaust is exempt from affecting warranty because it's after the cat and doesn't play any role in how the engine runs. People with brand new cars can get exhaust and keep their warranty. Or do you mean that you had full exhaust, including hi-flo cat or ORP? I also actually heard that you can clear an intake on your warranty if you can prove that it's higher performance than stock, then it doesn't void anything. I would have fought that a little more...Rodewaryer said:Mine basically melted down after a large coolant hose burst on a summer day in traffic in Phoenix. This was at 60K. Towed it to a Dealer since it was covered under warranty but after being assured the car didn't suffer any heat damage, it made it off the lot but never made another trip under it's own power and had to replace the engine at my cost since I had an intake and exhaust.
wow no warrenty cause u had a intake and exhaust. my dealer warrented a LS6 w/ a supercharger after the oil pump broke, GM can out and said it wasn't the supercharger that cause it and it got a new LS6. not fun putting a LS6 back into a CTS-V but fun driving it lol.Rodewaryer said:Mine basically melted down after a large coolant hose burst on a summer day in traffic in Phoenix. This was at 60K. Towed it to a Dealer since it was covered under warranty but after being assured the car didn't suffer any heat damage, it made it off the lot but never made another trip under it's own power and had to replace the engine at my cost since I had an intake and exhaust.
That class action suit should be in regard to premature brake wear you'll need very specific records to get on board.scsvtfocus said:There was a plastic pulley that became faulty...had it replaced. Then there was a knock coming from a crank as a result.
I took it to 4 different tech's and they all said the crank was going, so after 4 months or so I decided to replace the engine.
And for the hell of it, i looked on Craigslist for another SVT, and some guy replaced his engine EXACTLY at 113k. Same as mine. Concidence?
Then I received a class action suit notice about prior Focus that I owned, last week.
I will be speaking with them next week about there issue.
That sounds a little tough because you would need to get the Getrag tranny as well and that's pricey. It has different shift cables and yada yada. Even if the other components like alternator were a fit, changing from Duratec to Zetec sounds slightly complicated, but definitely possible.gospeedracer said:hey is it possiable to switch a 2.0 duratech with a svt 2.0 are all the other parts inerchangeable? you know water pump, alternator all that good stuff
That's right...Did you read the particulars on the website they provide?Cameroon said:That class action suit should be in regard to premature brake wear you'll need very specific records to get on board.
