1 - 4 of 4 Posts
Will 215/40/17\'s rub on a Pzev zx3?
Hey all,
I am tryin to save as much $$ as possible at the moment so I am lookin at used low-pros. I can get a good price on some 215/40/17's but the guy told me to make sure they wont rub on my car. Im pretty sure I've seen people with 215's in this forum but wanted to make sure. Will they rub on my zx3? I can get a set of 4 with pretty good used tread for $150. But they also have some 205's new for $300 out the door with mount/balance, but like I said, baller on a budget
Anyways thanks in advants and I hope I can stick these 215's on. BTW I am getting some 17x7 rims to match them, either Rage or enkeis 4x108 bolts. Thanks
Re: Will 215/40/17\'s rub on a Pzev zx3?
If your car isn't lowered then you wont rub. If it is, you might depending on what offset wheel you get. Stick between 42-45mm offset and you'll be just fine.
i had svt wheels on my sedan with 215/40/17 and didnt'rub too much... (once the tire pushed the fender lip up it didn't rub at all) and im lowered quite a bit.
as mentoined just go with a 42mm offset rim and those tires will be perfect...I will be doing the 215/40/17 setup with my SHM rims 42mm offset planted on the H&R cupkit which is a 2.7" drop all the way around...not worried one bit about rubbing
1 - 4 of 4 Posts
