1 - 4 of 4 Posts
When I have my windows rolled down all or most of the way down, they rattle when closing the door (not slamming either!) When rolled up they are firm as they should be.. Is there some sort of missing stopper that keeps it from rattling while rolled down? or do all foci do this
Edit: they are manual zx3 windows
The windows are held in via two clamps with rubber inserts.
and the track that the clamps that move up the window are held in via 4 bolts, 2 per side. up and bottom.
remove the door panel and see what you find loose.
Discussion Starter #4
Ill check the bolts and see if thats the problem. Thanks for the help
1 - 4 of 4 Posts
