What about the rear?
Refilled mine...Passenger Side: 19"
Drivers Side: 21"
You need to buy a whole blade assembly (including the metal bracket holing the blade) as the factory blades can't be refilled.
I did the first time too but they are not meant to be refitted.Refilled mine...Passenger Side: 19"
Drivers Side: 21"
You need to buy a whole blade assembly (including the metal bracket holing the blade) as the factory blades can't be refilled.![]()
Why do you say this? I've used the Anco brand refills twice with no problems.I did the first time too but they are not meant to be refitted.Refilled mine...Passenger Side: 19"
Drivers Side: 21"
I just replaced the whole assembly. The only problem is is that they don't come with the wind deflector. There's a reason they put that on there I'm sure.
