1 - 12 of 12 Posts
So I got the box in and all wired up. Was going through the checks to make sure it all works and I got through the first two. When I go to do the two step it won't engage. I'm pretty sure I have found the issue why. When I bring up the interface it's not reading RPMs. Have checked everything like the install instructions said but can't figure it out. Any help would be great. Thanks
Shaun (Doc) Daniels
I hope someone with some direct experience chimes in, but I know in other areas like adding an aftermarket tach the Focus gives problems due to how the ignition signal is designed. The zetec fires two cylinders at a time, one on the power stroke the other on the exhaust, and that screws up the rpm signal for some things.
Ford made a tach driver add on module for this, part M-17361-A200 (discontinued) to get around this.
You might need this, I'm not sure. They come up for sale from time to time, I grabbed one for use with my eBoost2 in case I ever get to the point of setting a different boost level in each gear. Good luck!
Actually got it all figured out. Had to tap an injector. All is good now.
Shaun (Doc) Daniels
Yea I should be able to do that. It actually works pretty well for what it is.
Shaun (Doc) Daniels
Is it the same wot box for like the mazda 3 and srt 4? And does it pop pretty good off to 2 step? I really want to see a video of it to see how I like the sound and stuff if possible thanks again
Discussion Starter #8
Yea the box is just a universal part. Come with long ass wires. I have to see where the girlfriend bought it since it was a gift.
Shaun (Doc) Daniels
Doc, you tapped off of an injector lead?
I thought the Focus was batch fire injection, not sequential, so I'm curious how it is reading rpm off of that?
Discussion Starter #11
Not really sure at all. I talked to the people that actually make the box and they said the only car that uses the camshaft sensor was the SRT 4. I guess there have been a couple people on here that were able to use it though.
Shaun (Doc) Daniels
Rpms in the wot box will be read by injectors, cam or crank sensor you will need to choose a different rpm source (voltage from the sensor) in the drop screen while programming, needs to read rpms so the 2step engages under 1,500 rpms which uses as a reference. It it was even more programmable there is a pin in the ECU of our cars for an external tachometer.
1 - 12 of 12 Posts
