Your ride! Pics and Links only!
99K views 65 replies 55 participants last post by  TbagFocus
#1 · (Edited by Moderator)
OK so this thread is STRICTLY for posting links to your Rigs/Build threads elsewhere on FJ or the net showing your setups!
Cars do not have to be poking or stretching tires, although it is what we are about, to be posted here but they do have to fall into the Slammed/Stanced look.
Cars with 3+" drops only or beyond what any spring/shock combo will drop you (otherwise you are NOT "slammed") ;)
NO TALK
NO BANTER
NO QUESTIONS
NO RANDOM PICS OR SMILEY FACES
NO WORK IN PROGRESS
FINISHED/DRIVEABLE CARS ONLY
Note: The latter is just to keep this on topic and with cars showing functioning stanced setups rather than test fitting/no where near done cars. Might seem harsh but save that for your build thread and post here once your are done and driving it!
Please preface each link/post with a SINGLE Pic of the car inside said link for quick reference.
If you have multiple cars or multiple threads please post them together in a single post.
If you buy a new car, edit your existing post to add your new pic/link.
New edit: ****
If you have or have had multiple setups on one car that are drastically different in look/fit/parts, please post one pic and specs for each setup.
If you have the same setup with noticably different specs on the wheels and tires please post pics with one pic and different specs for each. (eg: show wheels and DD wheels but both must still qualify for this thread like Drama or Zinger have. If you DD on stockers or wheels that fit nothing like your other setup, save that for the build thread! Again this thread is about showing aggressive fitments, we all know how a 17x7 40-49et wheel fits! ;) ) **** :New Edit.
Since this option sorta fizzled out in the stance council thread amongst all the talk/questions, please post your specs below your link in the following format:
Wheel Brand/model/Spec(size/width/offset):
Tire Brand/model/Spec:
Suspension parts:
Drop(fender heights are acceptable) and alignment spec (camber and TOE!):
Please use the "report this post" function for anything other than a properly formatted post so the mods can delete said post to keep this thread on topic.
Thanks!
LIKE THIS KIDS.... LIKE THIS!
Wheel Spec(size/width/offset): 07 shelby gt500 reps, 17x9, 18et
Tire Brand/model/Spec: Firestone Firehawk wide oval indy 500, 205/40/17
Suspension parts: H&R coilovers F:threads all the way down R: perches still on with two coils cut, rear shims on shock tower, stage 3 camber arms
Drop and alignment specs: N/A
http://forums.focaljet.com/team-rigz/642542-09-focus-history-lesson.html
#5 · (Edited)
#8 · (Edited by Moderator)
Wheel Brand/model/Spec(size/width/offset):Work Ryver 3pc 17x8.5f et30 17x9.5r et35
Tire Brand/model/Spec: Ventus 205-40-17
Suspension parts: KW Coilovers(1) Dom's rear camber arms
Drop and alignment spec:UNK/UNK
By jinstall at 2011-02-08
_______________________________________________________
Wheel Brand/model/Spec(size/width/offset):ATS/Luma/17X7 42et
Tire Brand/model/Spec: Nitto NT-01 205-40-17
Suspension parts: Custom H&R Coilovers, 3 way adjustable rear sway, poly bushings, adj end links
Drop and alignment spec: FR 4" RE 3.5" FR -4deg RE -2.5deg
By jinstall at 2008-10-18
I still have both, silver in the US and the blue in Germany.
#9 · (Edited)
Wheel Brand/model/Spec: ARE 3pc 5-spokes 16x7 et25
Yoko S-Drives 195/40/16
Suspension parts: KW V1 Coilovers, LCR Front Plates, SPC camber bolts
Drop and alignment spec: -6* front, -2.5* rear; 22.25"F, 23"R fender heights
Wheel Brand/model/Spec: BBS RS 17x8.5 32et, 17x9.5 40et (driven at 34et with 6mm spacer)
Tire Brand/model/Spec: Conti-3's 195/40/17 & 215/40/17
Suspension parts: KW V1 Coilovers, LCR Front Plates, SPC camber bolts, Dominant Engineering camber and toe arms.
Drop and alignment spec: -2.8* front, -3.9* rear camber; 0 toe (thrust set) f&r; 22-5/8th"F, 23"R fender heights
P1012652 by ZX3Tuning, on Flickr
http://forums.focaljet.com/team-rigz/615111-return-glory.html
#10 · (Edited)
Wheel Brand/model/Spec(size/width/offset): Simmons Type-670
F: 16x8.25 +34.875mm
R: 16x8.75 +41.225mm plus 5mm spacer = 36.225mm ACTUAL offset
Tire Brand/model/Spec: Yokohama Parada Spec 2 205/45/R16
Suspension parts: Ksport
Drop(fender heights are acceptable) and alignment spec: 22" F/R, will look for alignment specs
Rigz:http://forums.focaljet.com/team-rig.../team-rigz/632503-second-coming-56k-take-walk-showfield-liquid-d23-content.html
Wheel Thread: http://forums.focaljet.com/tire-rack-tires-wheels-brakes-forum/625218-simmons-type-670-56k-idk.html
Old Car Rigz (possible spec stuff):http://forums.focaljet.com/team-rigz/619924-omg-low.html
#13 · (Edited)
Wheel Brand/model/Spec(size/width/offset): Ford Fiesta ST wheels
Tire Brand/model/Spec: 205/40/17
Suspension parts:
Technix Coilovers
Drop(fender heights are acceptable) and alignment spec: Coilovers set on the lowest setting. which is 120mm (altho it doesnt look as low as that in my opinion)
More pics - http://forums.focaljet.com/team-rigz/651728-uk-focus.html#post7708796
#14 · (Edited)
Wheel Brand/model/Spec: Work Meister S1 2pc. 17x8 35mm
Tire Brand/model/Spec: BF Goodrich g-Force T/A KDW 2 205/40/17
Suspension parts: Koni Coilovers, Massive adj. rear toe and camber arms, Keegan Komponents Adj.,Ext. Front Anti-Sway Bar Endlinks
Drop and alignment spec: none 22.50 front fender 22.75 rear fender
More lower complete pictures coming soon!
#16 · (Edited)
Wheel Brand/Model/Specs Rotiform BLQ 17x8 ET30
Tire Brand/Model Ohtsu FP7000 205/40/17
Suspension Parts KSport Kontrol Coilovers, SPC Camber Arms, Keegan Komponents Toe Arms
Fender Heights & Alignment Specs 21 7/8" Front, 22" Rear. Front Camber = -1.4°/-1.5° Rear Camber = -2.9°R
Old Setup:
Wheel Brand/Model/Specs ESM 004 17x8 +38 Front, ESM 004 17x9 +40 Rear
Tire Brand/Model Falken Ziex 512 205/40/17 Front, Ohtsu FP7000 215/40/17 Rear
#17 · (Edited)
Wheel Brand/model/Spec(size/width/offset):BBS RS 17x8.5 39et
Tire Brand/model/Spec: Dunlop direzza spec dz101 205/40/17
Suspension parts:eibach pro street types S.. Kw v1 front struts
Drop(fender heights are acceptable) and alignment spec: front treads all the way down past treads, Helper spring still there. Rear perch removed cut one coil... camber 2.7* front 1.5* rear with no adjustments
Update fender height
F:22in R:22.50in
#18 · (Edited)
Wheel Brand/model/Spec(size/width/offset): OEM Mercury Cougar 16x 6.5 (offset: unknown)
Tire Brand/model/Spec: Khumo Esta's 205/50/R16
Suspension parts: Raceland Coil-overs, SPC rear Camber bolts
Drop(fender heights are acceptable) and alignment spec: 23" in front and 23 1/8" in rear
Suspension parts: Raceland Coil-overs, LCR front camber plates SPC rear Camber bolts
Drop(fender heights are acceptable) and alignment spec: 22.5" in front and 23 in rear
Wheel Brand/model/Specs: 17x7.5 Rota Subs et45
Tire Brand/model/Spec: Dunlop Direzza DZ101 215/40/17
Suspension parts: DGR Coilovers
Drop and alignment spec: Coils all the way down with 10K spings front and rear. No camber adjustments.
Fender Height: F=21.3" R=24"
THE CAR IS NOT DRIVABLE THIS WAY.
Wheel Brand/model/Specs: 16x7 Rota Slipstream ET40
Tire Brand/model/Spec: Nitto NeoGen 215/40/16
Suspension parts: KW V2 Front, V1 Rear
Drop and alignment spec: Coils 3/4"from bottom in front, Non adjusted in rear.
Fender Height: Not sure, I'll check tomorrow, if I remember.
#21 · (Edited)
'93 Cobra Reps, 17x8.5 +23
Nankang AS-1, 195/40/17 Front, (Some chinese brand) 205/40/17 Rear
Suspension parts:
D2 Coilovers, Koni Yellow adj. shocks rear. SPC Camber Arms, HTP Toe arms, & camber bolts.
21.75" Front, 21.75" Rear
Alignment specs:
LF: -2.2* camber, 0.02* toe
RF: -1.9* camber, 0.00* toe
LR: -3.8* camber, 0.00* toe
RR: -4.5* camber, 0.06* toe
Coming soon: Smaller OD wheel/tire combo and lowering coilovers more ;)
#22 · (Edited)
16" BBS RXII 2 piece wheels
(some Chinese brand :) ) 205/40
Suspension parts:
DGR Coilovers, SPC Camber arms, Dominate 5x100 swap, 12 mm spacers for rear and 5 mm spacers for front on their way.
Drop(fender heights are acceptable) and alignment:
21.3/4" Front 21 7/8" Rear, 1.9 and 2.0 deg of front camber and 2 deg of rear camber
(more low coming next week)
17x8.5 & 17x9.5 Sawblades coming soon...
#23 · (Edited)
Schmidt Modern Lines
Front:16x7.5
Rear:16x9
Both et35
Yokohama S-Drive
Front: 195/40-16
Rear: 215/40-16
Suspension parts:
DGR Street Spec Coilovers
SPC camber arms
SPC camber bolts
Front: 22.2"
Rear: 23"
front camber: -2.3*
rear camber: -3.1*
-gabe
bumping this to get people to update their posts with correct alignment specs as you all should have them by now.
Also have added the option for guys who have tried multiple setups to post a pic and specs for each setup. Please add to your existing post....
