60-0 times
2 reading
3.7K views 21 replies 9 participants last post by  natedog_1959
What are the stock 60-0 stop times for a SVTF? Thanks for any help!
IIRC 118 ft.
118 isn't too shaby for a stock car. Wonder what it would be like with R-compound tires and the brembo kit....If I won the lottery
I guarantee any SVTF is much less than 5.4 second with the stock brakes. Here is a little something I found:
Based on pure math, it is evident that there is a very large difference in the reported performance tests and reality. Assuming a deceleration rate of 32 fpsps (1g), calculations indicate a braking stop time of 2.75 seconds (88/32). Distance traveled now is calculated to be 121 feet, which is for all practical purposed, the published performance figures, excluding reaction times.
I would say our cars can pull very nearly 1 g of braking force, so 2.75-3 seconds seems entirely possible.
Nate
yea i would have to agree with you there, 5.4 seems like much too long. I thought the brakes on the FSVT were pretty good too, especially with the size discs and weight of the car.
word
What about all of the magazines that have done tests with different brake pads and found signifcant differences in stopping distances? Not saying tires don't make a huge difference though.
Primaris said:
Brakes do not matter it is the tires that will make a car stop faster.
http://www.teamscr.com/grmbrakes.htm
I don't have time to search the internet for them. I remember one test in particular that tested a stock WRX then replaced the pads with Hawk HP plus pads. The HP plus pads knocked 15 feet off its 70-0 distance. Try telling brembo or Hawk or EBC that aftermarket pads and rotors don't mean anything beyond heat management.:dunno: granted Ive heard of big brake kits that increased braking distances but thats because some ABS systems (usually 4 channel) don't like them.
Primaris said:
Got a link to the articles you mean?
Actually they won't agree because their only goal is to sell more brakes.
If you have undersized brakes, no tire in the world will give you the stopping power you want. Conversely, if you have amazing brakes and crummy tires you will have long stopping distances. Larger brakes will give you better initial torque and better heat dissipation at the expense of (possible) higher inertia from their increased mass/weight. I think I am going to do some testing of my own on a back country road with my stock tires and then again in the spring when I get my new Falkens. Nate.
Try it out sometime. Break out the tape measure and a cone. Use the cone as your starting point and mark off about 130 feet with some chalk. Have a friend measure your distance back from 130 feet and there you have it. You could do the test multiple times to see how your car reacts with cold and hot brakes. Just make sure the friend stays out of the way. Nate.
Since the test won't be back to back it will not mean anything. You would have to test the tires on the same day same place at least. The SVTF brakes are in no way undersized. Read the link I posted above the information is from Grass Roots Motorsports magazine and it's really good information.
I've read that stuff and it's good info. As long as I pick a day with similar temperatures, it will be for all intents and purposes an acceptable test. Remember, we are measuring in feet not inches or mm's, so I don't think the test will need to be that scientific. If I knock off a few feet in stopping distance (3 or more), I will conclude that the tires shortened the stopping distances. It may be all for naught though, as I am planning on getting Hawk HPS pads and plain Brembo rotors in the spring as well. Maybe I will do a back to back with just the new tires and then the new tires and brakes once they are bedded in properly. Nate.
