<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by belacyrf:
No.. not the same.. higher compression has a better chance of causing detonation. And with a turbo you are not always under boost.. so those times when your at full boost and raising the effective CR will be less often. Thus less stress on your internals.<hr></blockquote>
Ok but If I run compression of 8:1 for example .. And I get 15psi of boost .. I calculated it and it gives me 16.163265306122447 for Effective Compression .. If I have 9.6:1 (zetec) and put 10 psi of boost, I get 16.130612244897957.. I thought we we're looking for 14.1 (ideal) ? At so, what your saying is even If I have an effective ratio of about the same thing, I will get more power out of the 8:1 static compression with 15 psi, than with 9.6:1 with 10psi of boost ..
But at 8:1 static compression .. my car would run like **** if I didn't have any boost wouldn't it ? Because I'm lowering static compression for the turbo that gives me the extra missing power (and more) but if I don't create any boost .. I'm screwed
What ideal effective compression ratio are we looking for here? And does it matter which static compression your running and boost? What do I NOT want to go over? (numbers)
Bottom end = Crank, Rods, Pistons (and some would say the block)
Lower compression ALLOWS for higher boost and WILL produce more power. Not more power than high compression at the same boost, but more power than high compression at low boost. With Higher CR engines you WILL hit a wall as to how much boost you can run. Lower the compression.. and you have further you can take it.
Tom would probably say that the engine lasting is REALLY going to depend on your fuel solution. You can do many things (within reason) if you can get enough fuel to accomodate the new air flow!
Maybe some of the other guys can actually give you the mathematical calcs to see what at what ratio effective compression rises under boost. To see why power increases!<hr></blockquote>
Ok so crank is crank shaft right?, rods and pistons .. hmmm, getting 8.x compression pistons would lower compression but won't really be more durable than the 9.6 I got now right? (unless reworked or something)
And what If I run 94 octane instead of 91 for example .. will it make a difference between both setups? Or will 9.6 require more higher octane fuel? (I guess it will..)
Ok now for the A/F ratio, Project_ZTS said that 12.5:1 was ideal ratio for air and fuel mix .. how come I read 14.7 was ideal?! 14.7:1 would mean Leaner than 12.5:1 right?
There's so much different ratios, how to keep track of all of them
I love you guys, I'm learning so much lately
