Hey guys hope im posting this in the right place, but I have a feeling im getting F'd at the shop!
I have a 2000 Zx3 Hatchback as u know with the 2.0 Zetec. I took the car in to have the extremely bad timing belt replaced along with the water pump cause the car began to over heat a bit, also to check the motor and tran mount for failures because Ive been getting alot of vibration through the steering coloum at idle, and I know the foci are know for that.
Now the car ran good, and smooth the day I droped it off, then 3 days later the shopped called telling me that it was fixed an that it had a rough idle and a misfire and if it was always like that.....I told them well hell no, didnt you guys pay attention to how the car ran before the work was done? that was my first question I asked them. Seems like common sense to me.
well now 2 more days later they told me that they did have the car off timing and it runs better but there is still a mis, So I replaced the coil, wires and plugs once i realized after 160,000 miles it was for the most part the original stuff..
So the car still has the same misfire and a pinging coming from the cars exhaust, now the shop is telling me it is the catylitic converter an that it is 80% plugged.....
Im still convinced that the car is still out of timing, if they did the job correctly it should run as good as it did when I dropped it off, cats just dont automaticly cause your car to misfire in 24 hrs.. I think this shop is full of ****!!!!! Can you guys help me out here.:rant: Ive been driving the car for like 6 months with no problems
