Any ideas on how to loosen the spring on the 65mm throttle body?
486 views 7 replies 6 participants last post by  orb
Title says it all.I'm racing tomorrow night and would hate to put the stock TB back in place.The problem is the Focus Central TB spring is soooo tight it's sticking open.Any help/ideas are appreciated.THANKS!!
ENGINE MODIFICATIONS:
esslinger UDP/esslinger adj cam gears/focussport wires/focussport cool-flo(in my closet)/BPT intake pipe(in my closet)/focussport catback/focussport race header with flex pipe/Injen CAI/Venom hi-flow fuel injectors/Fidanza lightweight flywheel/Focus central 65mm throttle body
INTERIOR MODIFICATIONS:
b&m shifter/aluminum gauges/carbo fiber trim/KKM pedals/KKM window cranks/KKM dead pedal/MOMO shift knob/KKM brake handle
SUSPENSION MODIFICATIONS:
Eibach front & rear sway bars/H&R springs/Energy suspension hyper flex system/Energy suspension motor mounts/Enkei RS-6 16x7/Kuhmo Escta supra 205/50-zr16
EXTERIOR APPEARANCE MODIFICATIONS:
Morrettes quad headlight conversion/Lund X-terminator hood shield/euro spec upper and lower grills/custom tinted rear taillights/euro spec rear bumper
Stuff sitting around awaiting installVenom hi-flow fuel pump/RS front bumper/MSD DIS-2 ignition/catco hiflo catalytic converter
smedly1, now obviously I haven't put mine on the car yet since I have the little automatic problem, but sitting here playing with the TB it seems like the extemely tight spring wants to slam the thing closed. Are you sure something else isn't sticking? If the spring tension is really the sticking problem it will be difficult to loosen the spring since the TB assembly won't let you over compress the spring. Sorry no real good ideas.
2001 Pitch Black ZTS
Leather, AdvanceTrac, Side Air Bags, Automatic
Mods
Performance: Iceman Air Intake, No Chip for Me :(, ASP Underdrive Pulley, Focus Central 65mm TB on the way!
Style & Appearance: Hiper Xenon Headlights, 20% Tint
Sounds: RF 400a4, RF 600a4, Kicker x3i crossover, Alesis MEQ 230 30 Band EQ, CDT High Definition Series 3-ways, Infinity Kappa 5x7s, 2 Perfect 10.1 Subs.
Smedly,
I have tried opening the tb open and loosening the spring one complete turn. It loses all of its spring then and will barely close if you do that.
Therefore, I strongly recommend just opening and closing the tb for about 20-30 minutes continiously..That will help wear away some of the areas that may be sticking, and will also help loosen the spring.
Cory Haines
Operations Manager-
Modern Performance
www.modernperformance.com
proud sponsors of focaljet.com
proud owners of project 00 focus kona
*160hp 160lbs of torque*
mods so far- Iceman intake, Focuscentral 65mmtb, Thermal exhaust, Esslinger UDP, Esslinger intake cam,Esslinger cam gears, JBA header,Energy Suspension rear torque bushings,Progress lowering springs and rear swaybar. Fiber Images carbon fiber hood, Kaminari rear carbon fiber wing, Corbeau Targa RS racing seats (pair,European grills and clear bumper lenses. , Piaa H4 supewhite bulbs and superwhite 55 watt fog light bulbs, Black carbon fiber dash kit.
Many more top secret parts in the making / on order
Wanna see pics ? Click here-
http://www.modernperformance.com/mpxfocus/
I just came back from a 60 mile mountain drive.One thing I noticed,going downhill she revved to high heaven.This did not occur on uphills and once I got out of the city,it stopped happening on level ground.This got me to thinking could this be a combination of two very new mods?
1>Fidanza lightwieght flywheel
2>Focus central 65mm throttle body.
I haven't touched the spring on the TB cuz I figured a good dose of high speed mountain driving where I am constantly applying the gas and shifting would give the spring a thorough workout.
