Is there anything i can use to clean the engine and engine bay?
Greased Lightning is the best over the counter stuff I've used. Make sure the engine is warm and you wet it down before you put degreaser on.
Hmm... I'll have to try that!I use a can of Gunk Foamy Engine Brite and a can of foaming tire clean/shine (with silicone).
First use the Gunk as directed on can. Next spray on the tire dressing everywhere. This will actually help remove any dirt buildup the Gunk missed. Close the hood, then start the car and drive around for a while (usually 30minutes does it). Lastly pop the hood and wipe off any excess crap.
I hadn't cleaned my motor for probably two years before my brother showed me this method. My motor looked brand spankin' new, and I really didn't even get my hands dirty.![]()
All I have to say isAfter Foamy Engine Brite:
As you can see it does wonders![]()
Define "hot and runing"What i always been doing to my motor is , with the motor hot and runing, spray down the engine and everything with any type of an all purpose degreaser, shut the hood for about 5 minutes with engine still runing. Pop the hood and rinse , i do this about 2 times then after i rinse it really good i spray an armorall or a tire shine while the engine still is wet. Shut the hood, shut the motor down go inside and in about 1 hour check it out , looks brand new and shines really good ...![]()
I've never had any problem doing it this way,,whats the diffrence if you been driving around and hit a big cold puddle ,,,, water all over the bottom of your engine .. same thing...besides i been doing this for about 10 years now and never had anything warp on me yet ..What i always been doing to my motor is , with the motor hot and runing, spray down the engine and everything with any type of an all purpose degreaser, shut the hood for about 5 minutes with engine still runing. Pop the hood and rinse , i do this about 2 times then after i rinse it really good i spray an armorall or a tire shine while the engine still is wet. Shut the hood, shut the motor down go inside and in about 1 hour check it out , looks brand new and shines really good ...![]()
Define "hot and runing"![]()
Car care sites and folks do not recommend you spray water on a hot engine. Cold water on hot metal makes for rapid contraction/expansion resulting in possible warpage or damage![]()
Besides, a lot of people on here and other sites are anti-Armor All because it tends to dry out the plastic/rubber parts.
I agree, you should just hand clean it, get a towel wet and clean it, i mean if you take care of your car and clean it often you are never going to need that junk to take off grease buildup, and dont just hose the engine down that wont do much and you take a risk of damaging something. even use a toothbrush and you can get in those tight places, but using a small cloth and a toothbrush prevents water from going where it shouldnt be going.Only got one suggestion that could save you some grief, spend more time cleaning by hand and less trying to spray some miracle stuff (that won't perform the miracle, face it) ALL OVER EVERYTHING. You will damage less components that way. Seen it happen to MANY people, hey, it's just a suggestion....
