i down shift alot and someone told me that it is bad is that that true?
In everyday driving, there's not really much call for downshifting, but we just about all do it anyway. If you are gonna downshift, there's no reason *not* to rev match....its what all the cool racer guys do, and it'll allow you to gently downshift...
CCC
So you think replacing a clutch is cheaper then replacing brake pads?Yeah, typically when I DS, I rev match to prevent any damage and the sudden jerk of my passenger's head. It's always a real smooth transition doing it this way. I try to do it to keep the brakes from wearing down so quickly. Of course autoXing doesn't really help my brakes out, but that's another story.![]()
So then explain how a clutch works. If the engine rpm is matched to the rpm of the clutch, then there is no slippage as the clutch mates up to the flywheel. Without slippage, how does the clutch wear?Supersonic - "Downshifting doesn't wear the clutch at all if you rev match and don't slip."
You don't really understand how a clutch works, do you?
You are giving bad and wrong advice.
Actually it's so you don't upset the balance of the car.Save the aggressive downshifting for the track where it makes sense to apply the proper heel-toe rev matching shifts.
Note: Even here, you still are not using the engine to slow you down, the downshift is to supply more power to the wheels for forward acceleration.
Hey supersonicsvt, I'm on your side. j/kI don't quite agree - dumping the clutch will wear the surface also. It's physics - the work of the engine has to be transfered thru the clutch, whether you take 50 milliseconds to clutch or 1000 milliseconds.
