Early signs of bad alternator?
17K views 20 replies 9 participants last post by  bmylez
Hello all, so sometimes ill be sitting at a stop light or stop sign and the battery light will come on and the car will kinda sputter, a few seconds later the light goes off and car is fine. are these the early signs of a bad alternator? if so what does one cost and can i put it in my self?
ummm before u say its ur alt. i thought the same thing and it was a 20 something dollar pigtail which is a SUPER common problem for the svtf , search in the forums for alt pigtail and u should find ALOT of info, also check all grounds , my buddy had some corrosion on one of his grounds and thought it was his batt or alt.
update. just got back from autozone, alt and battery and starter are all A ok, i will check grounds, and pigtails. another theory is the air conditioning compressor, i am not sure if this happens when the air conditioner is on i dont use it often (about as often as this thing happens, lol).
well i did watch him do the test with the little portable machine, i even have the slip of paper that tells me the results. here is what he did, plugged in the machine, told me to turn the engine on, turn on high beams and AC full blast, turn off engine, this was repeated twice.
Alternators.....don't even want to go there. I wonder what the record is for number of alternators one SVTF has consumed.....If I don't have it I'd be surprised.
ok so update. i have found what may or may not be a bad ground. the wire coming from the positive terminale is beginning to fray. would this cause the symptoms described, especailly when making a hard right turn. i dont know if there is any correlation but sense stuff would want to shift to the left pulling on the ground
A wire coming from the positive terminal can't be a ground. That would be the opposite of what it is.
Anyway, frayed wires are never good, so try replacing/fixing it.
If your car doesn't have an aftermarket tune, I'd wager the diagnose is: It's an SVT Focus with a stock tune. They all did that stock. ;)
^^hmm, i dont mean to question your expertise but why would ford make a car that did that, and if this is infact true were there any recalls or anything that could be fixed under warranty, as for the grounds, where should i check to see if they are bad and what am i looking for exactly?
Yeah, get a remanufactured unit from Advance Auto. $180. If you're doing it for the first time...more like 2+ hours. Not bad at all, though.
