I honestly think you will get the biggest gain from the Cossy CAI, cause its the only "True" CAI,
Under_rated, I disagree with your comment that there's just one "true" CAI (Cold Air Intake). You will explain. LOL. The Cosworth CAI's filter and tubing inlet is in the same spot as Marcy's, FocusSport's and F2's are, which is down in behind the left front bumper/fascia. A "truer" CAI would sit in direct, cool airflow proper.
Now Cosworth's stuff is absolutely top-drawer, that's for sure, and theirs is the only CAI currently available that has a CARB (California Air Resources Board) E.O. (Executive Order) number; in other words, it's CARB-legal and therefore will not get your car impounded, even confiscated, for tampering with it's emissions equipment by installing it on a Focus registered in California and perhaps other "Green States" (New York, Vermont, Massachusetts and New Hampshire).
You say you "extremely" like the performance that piece gives you. Have you had any other CAIs on your car? If so, which ones? The other cold air intakes advertised for sale on [FJ]focaljet produce similar gains.
The restrictive "ring" you speak of is there for a reason; that's to develop similar airflow velocities to what's found going over the stock MAF (Mass AirFlow) tube's sensor. If your Duratec is built to flow what amounts to something over 200 HP naturally aspirated, then that ring can be replaced with another, slightly less restrictive one. It is never removed entirely.
You will pardon me if I sound a little harsh, but facts are facts.
:thumbup:
