1st question: How do I make the stock fog light switch independently? ie I don't have the have the lights on to be able to switch it on and it stay on when the high beam is on. is it even possible? the one I've seen from focushacks, I've heard it's not good because it routed the power through the switch in the cabin instead of through the relays.
2nd question:
how do I pull a harness to the cabin for aux./extra fog lights? which way is the easiest to go? is there any like grommet/hole cover that I can take off so I can put a harness for the fog light through?
I have sap btw, I'm thinking of mounting the fogs in the lower grill area and hack a few of the grills of for opening. it's all black so should be good.
any suggestion and ideas are welcome
2nd question:
