IgorDEARBORN, Mich. — Ford Motor Co. said it will shift gears and de-emphasize big sport-utility vehicles over the next four years to center more attention on cars and crossovers, according to a report in Autobeat Daily on Wednesday.
Ford President of the Americas Mark Fields said Ford will introduce a subcompact for the U.S. in the 2010 model year. When asked why the company hasn't moved faster to import one of its Asian or European subcompacts, Fields said the company avoided the "easy" badge-engineering solution to make sure it has the right car for the U.S. market. He said Ford won't use imports to fill the gap between now and 2010.
Fields also said the company is shifting its vehicle portfolio and product development investments to match consumer demands. SUVs were the mainstay of Ford's product portfolio in the 1990s.
What this means to you: Ford's Way Forward plan now includes more crossovers and at least one small car — but will it be too little, too late?
Because when Mark Fields took over they scrapped that project. It's been discussed here several times.uujjj said:um, a few years ago ford was considering introducing a b-car for 2008. why the extra 2 years?
THANK YOU.Ford Motor Co. said it will shift gears and de-emphasize big sport-utility vehicles over the next four years
You'll never beat the space efficiency of a front driver, but if they are considering AWD, then why the hell not RWD? RWD has close to FWD cost, weight, and efficiency (meaning more power to the ground and better fuel economy) with improved weight distribution, more suspension room up front, and w/ modern stability control systems is just as "safe" as AWD (afterall, the AWD only means all wheel power). Actually, hell, just make a little mini-hybrid with direct-drive electric motors on the front wheels for low-speed traction (disengaged w/ a clutch at speed), which by their very nature will work as generators for regenerative braking (re-engaged when applying brakes). That'll fix the RWD concerns above the snow-belt.They were putting most of their efforts on fwd (or fwd/awd) platforms.
Though we really wouldn't mind if you did that to hold us over so that we don't give up on youMark Fields said:Ford won't use imports to fill the gap between now and 2010.
In the hands of an IJAC, they are.Ducman69 said:stupid scoobaru has everyone convinced RWD cars are more spin-prone to their "safety AWD".
It's not financially prudent. To federalize a car (emissions and crash) it costs MILLIONS and MILLIONS of dollars. They won't do it for a short product cycle.2focusd said:Though we really wouldn't mind if you did that to hold us over so that we don't give up on you
Not with a good stability/traction program though, thats what I'm saying. I've got 460hp in the driveway (and corresponding torque), yet I can still completely plant my foot on it in the rain and its not gunna spin me around.focaljet-1 said:In the hands of an IJAC, they are.![]()
True and false. It is true it will be 50% more power to the rear wheels than in a perfect 50/50 split AWD system. It would only MATTER if the "extra beefiness" actually increased the physical size of the rear differential or driveshaft significantly, and let us not forget that there is no center differential to worry about. Any 50/50 AWD system needs to be able to handle more than 50% of its traction going to the rear wheels, such as on a hard launch where the acc. is going to squat the rear of the car unless your suspension is ungodly stiff. So instead of building in an extra 50% capability, its really only say 25% extra max capacity. Furthermore, we are talking about new B-segment cars here, the power is not likely to be massive, which again makes the weight, cost, and extra losses for an AWD transmission silly when a pair of rear wheels would work fantastic. The engine also doesn't even have to be in the front of the vehicle (flat inline/boxer four could power the rear wheels), but even up front if you absolutely insisted on a short stubby nose you could go for a V4 (only two cylinders long) or even a small six like a 1.8 liter Honda Goldwing engine.A primary rwd car would have a more beefy driveline going to the back since it has to carry 100% of the torque 100% of the time if it is to be offered without the awd.
Wouldn't it really be 100% more capacity?Ducman69 said:True and false. It is true it will be 50% more power to the rear wheels than in a perfect 50/50 split AWD system. It would only MATTER if the "extra beefiness" actually increased the physical size of the rear differential or driveshaft significantly, and let us not forget that there is no center differential to worry about. Any 50/50 AWD system needs to be able to handle more than 50% of its traction going to the rear wheels, such as on a hard launch where the acc. is going to squat the rear of the car unless your suspension is ungodly stiff. So instead of building in an extra 50% capability, its really only say 25% extra max capacity.
Yeah, why badge engineer something to get it here in a timely fashion?When asked why the company hasn't moved faster to import one of its Asian or European subcompacts, Fields said the company avoided the "easy" badge-engineering solution to make sure it has the right car for the U.S. market.
I agree 100%.rejectZX3 said:i'm still hoping against hope that they build that Bronco, and not change it much from the show version
