2001 se wagon, manual, ABS model
changed rotors, pads, drums, shoes and repaired a rear pipe(leaking)
ABS light has been on for a long while... didn't think that would be significant but...
Since then the front calipers are not returning after brake application, causing drag, high temperatures at both front wheels. I think gas mileage is suffering too, car feels like its not happy, power feels down.
I jacked the front, removed calipers and rotors( a little tight but easy when piston compressed) and ran the speed up in 5th gear(140km/hr) for a while. No heat at the hub bearings, no noise either.
When I did the same with the wheels, rotors and calipers on the calipers got quite hot.(After brake application)
So the fronts are not fully releasing, what the heck?
