Great Lakes Fun racing
965 views 45 replies 9 participants last post by  focuspl99
anyone up for it? Either Tuesday or thursday next week, whenever its available if the weathers good.... i wanna go one last time before it closes
i think my and my buddy with a 5spd scion tC are going up....... anyone interested in a lil g2g up there?
i ran it this past week....traction was a real big issue....on street tires at 12 psi it went 14.7 at 96......with a 2.5 60'. i uped the boost to 14 ish and it killed my 60' even worse but my trap went to 98...i can run 16-17psi pretty safely on pump gas (no detonation). but im just not getting traction...i was spinning through 3rd on every run. its def a 13 second car with traction....or slicks
Just brought my new ride home last night. 81 mustang. it's going to be a while before it's up and going though. It's a solid car, needs a little tlc on the body, but it's begging for the motor i'm almost finished building.
280 flywheel hp 302 with built bottom end topped off with a 2 stage nitrous system. 150 [censored] in first gear and 200 in 2nd and third. should put about 420hp to the pavement and will weigh in around 2,800 lbs when in race form. Should be an easy low 12 sec car.
i sent everyone a pm who said they were going. if one of you could please give me a call if this goes through...ive got some work to do on the omni and hopefully ill get to bring it up...if not ill have a yellow spec v. so be sure to stop by if you see me.
matt
ill go...not sure if it will be the omni or the spec but ill go.....ive got a speed distance sensor prob with the omni...if i can find a replacement it should be good to go..and ive still got a little more tuning to do (i detuned it to pass emissions)
