jlhansen said:
Out of curiosity, would a linkage maladjustment cause the transmission refuse to go into 3rd? All the other gears engage normally. I recently replaced the roll pin and just thought my son ham-fisted it and broke something in shift fork when the pin failed and stranded him in a intersection. Prior to the pin failure there were no engagement problems in third. I tried to adjust the linkage while having someone inside the car hold the shifter, but it didn't seem to do anything.
If the adjustment is the culprit, is there a really good explanation of the adjustment procedure? I followed a step-by-step the first time and I'm not convinced that it will work for me. If there is some sort of tool/fixture used to hold to shift mass in place, is there a dimensional spec for building one?
On the adjustment, it doesn't sound like your problem. Its possible he damaged the 3rd gear synchros when he jammed it into gear. 3rd gear is the weak spot in these cars for sure.
When mine was out of adjustment i grinded going into 1st, and 5th. I could barely get it into 5th, i had to wiggle the shifter to make it fall in.
If you want to try to adjust it, pull the boot cover up and look at the shifter base. Center for the shifter will be as you see it visually. you want the shaft right inthe middle of everything perfectly. you can see in my pic that its equidistant from all sides. Then while holding it, have someone adjust the cable ends under the car.
It depends on what year you have, you may need to push a orange button or pull up a yellow collar to adjust your cable ends on the transmission.
you can get to the cable ends by taknig out the air box. Pull the air box straight up from one end or the other, it will pop loose from the rubber grommets. losen the tube from the throttle body and unplug the Mass Air Flow sensor and take the air box completely out of the car. then look down and to the back of the tranny. You will see it.
I am having clutch issues with my car currently that are keeping me from getting into gear at times. I will bleed that today to see what result i get.
