Need advice removing front wheel well liner
13K views 8 replies 8 participants last post by  bumble
I need to remove the front passenger side wheel well liner so I can recharge the A/C. When I try to remove the two philips head fasteners next to the wheel, they just spin and don't come out. How do I get them out without causing damage?
LOL
It's not a screw, first off. Least not in the sense of how a normal screw functions. These are more of a push-pin.
Similar to:
Prying tool, as stated, will work just fine. Then you'll see it's 2 parts. Remove the center, push the outer in place then push the center in and it holds in place. It simply expands to hold.
Exactly. They don't come out by unscrewing 5 minutes after being put in. I stick a broken off exacto knife in between the two pieces to separate and loosen the center. A push pin made to look like a screw, fancy that (idiocy).
You don't have to pull the liner to charge a/c, I never have and I've done quite a few. The a/c setup needs long hoses on it though.
I know it's an old thread, but I found a simple way to pull the plastic inner pin out, without harming it; leaving both pieces usable for later reattachment. I've done this three times and am still using the original fasteners.
Screw a drywall screw about half an inch into the plastic center pin. Goes in real easy, with the fake Phillips head providing a good start. You might need to hold the pin from spinning by applying pressure with a finger to the plastic pin while you screw the drywall screw in.
Once screwed in ... you guessed it ... grab the drywall screw head with a pair of pliers or vice-grips and give a tug. The center should pull out leaving the outer plastic flange-piece to be pushed out from behind, or pried out with a suitable flat-blade screw driver.
Hope this helps someone out there...
Doxx
