<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>The 87 from the same company, ie, Mobil, would have the same detergents and additives as the 93.
<hr></blockquote>
By US federal law, this is true. I used to think the same thing, that hte additive packages were superior in their higher octane fuels. But HatchbackInBlack, I believe Alkemist was differentiating between the
different manufacturers (Exxon vs SuperStop). Thats why he mentioned using a well known brand. I think thats right in that some of those no name crap gas stations really use poor bottom of the barrel fuels with subpaar containment and delivery facilities compared to the major stations (and I'm sure that Texaco additives might vary slightly compared to Shells and so forth).
BTW, I'm not sure if you are familiar with this but there are different measuring standards for octane in the US and Europe. There is RON (research octane number) and MON (motor octane number). In the US, the average of the two is taken (RON+MON/2... check it out as its usually written on the pump); so as an example the ROV 87 pump gas that we pick up at the station would be 82 MON and 92RON. I believe that in the UK, only a pure RON octane rating system is used. Your 98 RON octane is most likely very similar to our 93 RON+MON/2.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Although i am utterly unconcerned with the pinging, I<hr></blockquote>
You should be... pinging can cause serious long term engine fatigue, and in extreme cases engine failure (just see what happens when turbokits are operated with non-existent or non-functioning supplimental fuel systems).
If you are pinging, you need to either go to a higher octane fuel or have the timing scaled back a bit.
There are those octane boosters you can find everywhere. But I haven't heard from anyone that noted they actually worked well at increasing the octane rating. P-51 knows more about them, but from what I've read... they should be avoided. Plus, its only a temporary solution anyway.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>I think I will try it out, and use 89 Octane next time. That should be good right?<hr></blockquote>
I'd go back to 87 octane after flushing your system with the fuel injector cleaner I mentioned (not sure if it does much for the rest of the combustion chamber). If you aren't pinging with that octane, you've found the proper octane rating. If you are, put in 89 in the next time (your knock sensor will automatically retard the timing for that tank of gas if it notices knock... and you should be able to hear it just before and feel the slight power drain right after). I could see how it is possible to lightly ping with a lot of mods (even w/o timing or compression changes) if you lived in a really hot climate and had a non CAI. But as I was saying... go back to what the engine was designed for (87 octane) and if you have no problems then you've got what you need.
Saves money and overall better for performance.
[ 01-08-2002: Message edited by: Ducman69 ]</p>
