i have"Motor Work:
Volant intake
FS exhaust
FS flex
magnaflow exhaust/with resonator
SCT super chip (7200 redline)
focus central pullies
Esslinger cam gears
Focus central TB(65mm)
2000 intake manifold
scream Demon Coil/wires
ford racing plugs
Cat stage 1 cams
crower spring/retainers
port and polished head
milled .040
lower FS motor mount
Quife Differential
Spec stage two clutch
Ford racing OEM flywheel.
Eibach pro-kit dampers/springs/sway bars
EBC green stuff pads
EBC slotted and studded rotors
2002.5 steeda short shifter
What would be the easyest-safest
to run???
Volant intake
FS exhaust
FS flex
Esslinger cam gears
ford racing plugs
Cat stage 1 cams
milled .040
Quife Differential
