The Nominations
CatMostFeared
2000 ZX3 Ford Focus
Performance:
Turbo Charged 2.0 Zetec 232WHP
65mm Throttle Body, 60lb Injectors
Custom Built Aluminum Intake Manifold
Nitrous Express Wet Kit(unhooked)
VF engineering Engine Mounts
Ingalls Engine Torque Damper
Fidanza Cam Gears
SCT ProRacer Tuning
Mafia Mass Air Sensor
5 Speed MTX Torsen LSD
Spec Stage 4 Clutch
Fidanza Aluminum Flywheel
Suspension:
H&R Coilover Suspension
Custom Built Chromemoly Strut Bars
Eibach 22mm front sway bar
Eibach 25mm rear sway bar
Konig Unknown 18x7.5 Rims
Kumho 225/40/18 Tires
SVT 4 Wheel Disc Brakes
Exterior:
Custom Paint: by Jeff Ater
House of Colors Paint
WingsWest WRC Body Kit
Turbo Cobra Fiberglass Hood
Euro St 170 Headlights /Grill
Custom Shorty Antenna
Interior:
AEM Gauges
SVT interior/pedals
Alpine DVD Player/PS2
Alpine 2x 10" Subs/ 4x 6.5
Alpine 650 Mono / 450 4 channel Amp
Battery Relocation to hatch
Cayse
Exterior:
FRPP Focus RS upper grille
Höen Xenonmatch foglight bulbs
black sidemarkers
full exterior LED bulb replacements
35% Llumar tint
Lamin-X clear headlight film
foglight mod
FRPP 17" black EAP wheels w/SVT center cap
Interior:
Recaro SVTf front seats
ST170 black center console w/blackwood shifter trim
MOMO Sphere Airmetal shift knob
MOMO Pit Stop Airmetal ebrake handle
Richbrook satin aluminum short gear shaft sleeve
FRPP short throw shifter
Redline Accessories custom leather shift and ebrake boots
Focus Central black anodized billet aluminum HVAC knobs w/red indicator
MOMO Stealth Airmetal pedals
Motorcraft cabin air filter
Under the Hood:
CFM 67mm throttle body
AEM polished CAI
black powdercoat ignition coil bracket
Taylor Thundervolt ignition wires
Motorcraft AZFS22C spark plugs gapped to .060
Focus-Power Diablo Predator tune
180° thermostat
4ga engine ground strap
4ga battery ground
Handling:
KYB AGX dampers
Eibach Pro-Kit springs
FRPP front strut bar
CFM lower engine torque mount
Progress 22mm rear swaybar
polyurethane rear endlinks
Kumho Ecsta SPT 215/45ZR17 tires
Powerslot slotted rotors
Hawk HPS brake pads
Egz
Passing a Hertz Mustang at Jetfest07 on Cali Speedway:
Engine:
Supertech 11.6:1 pistons
Eagle H-beam rods
Crane stage 2 cams
Crane valve springs and retainers
Cosworth balance shaft delete kit
Marcy Motorsports 3-angle valve job
Cosworth intake manifold
Marcy Motorsports CAI
Cosworth header + flex
Modified Tru-Bendz 2.5" Exhaust
ECU Tuning by Marcy Motorsport
Innovate LC-1 wideband
Ford Racing 39# injectors
Autolite 104 copper core plugs
Cosworth oil baffle kit
Ford Escape oil cooler
Transmission:
Cosworth flywheel
Clutch Masters Stage IV clutch
Quaife ATB LSD
3.82 final drive
Suspension:
Gaz height and dampening adjustible coilovers
Progress 22mm rear sway bar
Prothane lower control arm bushings
Carbotech XP8 brake pads (track)
Hankook Ventus R-S2 tires (track)
Exterior:
ST170 headlamps
Ghia front grill
Color matched hatch strip
Interior:
Modified S&W Racing 4-point rollbar
G-Force 6-point harnesses
Steeda Tri-Ax short throw shifter
VDO oil pressure and temperature gauges
OMP pedals
Sony CDX-GT510 MP3 player
SVTDuck
Drivetrain/Engine:
Cosworth flywheel.
Centerforce Clutch
Torsen T-2 Diff
VF Engineering Drivers Side mount
C-F-M Race bushing rear mount
Custom poly passenger side mount
Steeda Tri-Ax shifter
Trubendz 2.5" Magnaflow
Cosworth Intake
Cosworth 67 mm throttle body
Cosworth header
Cosworth Duratec flex pipe
Cosworth Intake manifold
3.82:1 final drive '05 spec box.
Hawker Odyssey battery
SCT XCal2 with Pro Racer package
C-F-M UDP
Massive Speed System Coils
All emmisions equipment removed
A/C Delete
Flex-A-Lite lightweight fan.
Suspension:
KW Competition 2-way race suspension (Coilovers)
P-51 Delrin rear shock bushings.
Eibach rear alignment kit
Auto-X-ZTS adjustable rear sway bar.
K-Mac camber plates.
F2 Front Sway Bar End Links
Brakes:
Brembo rotors
Hawk HP plus pads
Mocal Stainless Steel Brake Lines
Interior:
Cobra Imola 2 GT seats
Momo Pedals
Momo Shift knob
Autopower Oil Pressure and Water Temp gauges.
Momo steering wheel
Stable Energies Harness Bar
G-Force 5 pt Harnesses
Custom red/black shift and e-brake boot
Custom red/black rear seat upholstery
SVT e-brake handle
Rolling Stock:
Rain: Centerline 15x7” Neutron wheels with 205/50-15 Hoosier Radial Wet
Local: Kumho V710 225/50-15 on Kodiak 15x8.5" wheels
Tour/Pro: Hoosier A6 275/35-15 on Kodiak 15x8.5" wheels
5mm H&R wheel spacers for use with narrow wheels
ARP wheel studs
Appearance:
Body colored molding
Euro grills
Body colored lift gate handle
Mach 1 lip
S2 Rear Spoiler
Body colored door handles
SVT Overflow tank cover
Graphics by HotRodKris
Vinyl by BigdaddyZX3
F2 Flares
DGTL Toys
EXTERIOR:
Seibon Carbon Hood (uninstalled)
SVT Front and Rear Fascia
Limo Tint on rear windows
Ford European Grille
Ford MACH HID Headlamps w/ black housing
North Viking WRC Wing (uninstalled)
INTERIOR:
Sparco Torino Driver Seat
Razo Quick-Push AT Shifter
Broadway 330mm HID Mirror
SUSPENSION:
Rays Engineering Volk Racing TE-37 Cup 16x8 (f), 16x7 (r)
Tein Super Street Coilovers
H&R Rear Sway Bar
FocusSport Front Stress Bar
FocusSport Rear Stress Bar
Falken Azenis RT 615 215/45/16
Falken Ziex 910 205/55/16 (Stock Config)
BRAKES:
Brembo slotted rotors
AXXIS MetalMaster pads
ENGINE:
VF Engineering Driver Side mount
VF Engineering Passenger Side mount
VF Engineering Rear mount
Injen Technology Cold Air Box
Injen Technology Wire Cover
FocusSport Underdrive Pulley
FocusSport Wires
Ford Racing SVT Header
Random Technology High Flow Cat
McNews Automotive SVT Flex Pipe
A'PEXi World Sport Exhaust
A'PEXi Super Ground Stabilizer
Metal Zetec Engine Cover
