21 - 40 of 66 Posts
Wheel Brand/model/Spec(size/width/offset):
'93 Cobra Reps, 17x8.5 +23
Tire Brand/model/Spec:
Nankang AS-1, 195/40/17 Front, (Some chinese brand) 205/40/17 Rear
Suspension parts:
D2 Coilovers, Koni Yellow adj. shocks rear. SPC Camber Arms, HTP Toe arms, & camber bolts.
Drop(fender heights are acceptable) and alignment spec:
21.75" Front, 21.75" Rear
Alignment specs:
LF: -2.2* camber, 0.02* toe
RF: -1.9* camber, 0.00* toe
LR: -3.8* camber, 0.00* toe
RR: -4.5* camber, 0.06* toe
Coming soon: Smaller OD wheel/tire combo and lowering coilovers more ;)
16" BBS RXII 2 piece wheels
(some Chinese brand :) ) 205/40
Suspension parts:
DGR Coilovers, SPC Camber arms, Dominate 5x100 swap, 12 mm spacers for rear and 5 mm spacers for front on their way.
Drop(fender heights are acceptable) and alignment:
21.3/4" Front 21 7/8" Rear, 1.9 and 2.0 deg of front camber and 2 deg of rear camber
(more low coming next week)
17x8.5 & 17x9.5 Sawblades coming soon...
Schmidt Modern Lines
Front:16x7.5
Rear:16x9
Both et35
Yokohama S-Drive
Front: 195/40-16
Rear: 215/40-16
Suspension parts:
DGR Street Spec Coilovers
SPC camber arms
SPC camber bolts
Front: 22.2"
Rear: 23"
front camber: -2.3*
rear camber: -3.1*
-gabe
Discussion starter · #24 ·
bumping this to get people to update their posts with correct alignment specs as you all should have them by now.
Also have added the option for guys who have tried multiple setups to post a pic and specs for each setup. Please add to your existing post....
Wheel Brand/model/Spec(size/width/offset): ESM 009R 16x8 16x9 et 30 all around
Falken Ziex 512 205/40 front 215/40 rear
Suspension parts:
H&R Coilovers: Rear springs have 2 dead coils cut; Dominant Engineering rear camber arms
Drop and Alignment Specs:
Front 22" Rear 23"
Wheel Brand/model/Spec(size/width/offset): ARE/398/FRONT(15/7/25)REAR(16/7/25)
Tire Brand/model/Spec: Kumho/Ecsta/FRONT(195/50/15)REAR(205/45/16)
Suspension parts: B&G Coil overs
Fender Heights: FRONT (22 1/4) REAR(22 3/4)
Wheel Brand/model/Spec(size/width/offset): Elbrus/I05/17x7.5 et42
Tire Brand/model/Spec: Bridgestone/Potenza RE-11/ 215/45/17
Suspension parts: H&R coilovers, Keegan|Brock Development front endlinks, Keegan|Brock Development toe arms, Energy rear endlinks
Drop(fender heights are acceptable) and alignment spec (camber and TOE!):
23.25" front, 23.75" rear
Camber: LF: -1.7, RF: -1.7 LR: -1.8, RR: -1.8
Toe: 0 all around
Wheel Brand/model/Spec(size/width/offset): Borbet Type CB 16x7.5 et35 front, et30 rear
Tire Brand/model/Spec: Falken Ziex ZE-912, 205/40/16
Suspension parts: H&R coilovers, K|Bdev. front endlinks, K|Bdev. toe arms, Energy rear endlinks
Fender-Ground:
20.75" front, 21.00" rear
Camber:
LF: -1.8, RF: -1.8 LR: -2.1, RR: -2.1
Toe:
1/16" total (in) front, 0 total rear
Wheel Brand/model/Spec(size/width/offset):Fittipaldi Monolithic 16x7.5 et20 front, et20 rear
Tire Brand/model/Spec: Falken Ziex ZE-912, 205/40-16
Fender-Ground:
Camber:
Toe:
Wheel Brand/model/Spec(size/width/offset): Borbet/ Type T/ 17x7.5/ ET40-F, ET35-R
Tire Brand/model/Spec: Fuzion HRi 205/40-17
Suspension parts: H&R coilovers (bottomed out front, removed adjusters and mini-coil rear), Keegan|Brock Development front endlinks, Keegan|Brock Development toe arms, Energy rear endlinks
20.75" front, 21.25" rear
Camber: LF: -1.9, RF: -1.9 LR: -2.1, RR: -2.1
Toe: 0 all around
Wheel Brand/model/Spec(size/width/offset): Borbet/ Type B/ 16x7.5/ ET20-F, ET20-R
Tire Brand/model/Spec: Kumho Ecsta AST 205/40-17
Suspension parts: H&R coilovers, removed front lock collars, FSWerks Race Plates, H&R 60x100mm front springs, H&R 60x100mm rear springs, Keegan|Brock Development front endlinks, Keegan|Brock Development toe arms, Energy rear endlinks, Prothane LCA bushings F/R, SPC Camber arms.
20.5" front, 21.00" rear
Camber: LF: -2.4, RF: -2.4 LR: -3.5, RR: -3.5
Toe: 0 all around
Wheel Brand/model/Spec(size/width/offset): Ultra/ 128/ 15x7 et0
Tire Brand/model/Spec: General Altimax Arctic 185/60-15
Suspension parts: H&R coilovers, removed front lock collars, H&R 60x100mm rear springs, Keegan|Brock Development front endlinks, Keegan|Brock Development toe arms, Energy rear endlinks, Prothane LCA bushings F/R, SPC Camber arms.
21.5" front, 22.50" rear
Toe: 0 all around
Wheel Brand/model/Spec(size/width/offset): Napre / ARE / 16x7 et25F/et20R
Tire Brand/model/Spec: Falken Azenis RT-615K 205/40-16
Suspension parts: H&R coilovers, FSWerks Race Plates, Swift 60x150mm front springs, H&R 60x100mm rear springs, Keegan|Brock Development front endlinks, Steeda toe arms, Energy rear endlink bushings with custom hardware, Prothane LCA bushings F/R, SPC Camber arms with Prothane Bushings, Alex the Machinist steering rack bushings.
21.00" front, 21.25" rear
Toe:
F: .08 in (total)
R: 0 total
Wheel Brand/model/Spec(size/width/offset): Borbet Type C 16x7.5 et35
Tire Brand/model/Spec: Yokohama 205/40R16 Front, 205/45R16 Rear
Suspension parts: Bilstein PSS9 Coilovers, Eibach Swaybars F&R w/energy bushings,
Dominant Engineering: rear camber arms, toe arms, and custom LCA's with Bilstein sized spring perch, cut rear swaybar links and bushings in half for ground clearance.
Drop and Alignment Specs: Front 22 1/4" Rear 23"
Toe set at 0 DEG all-round currently, camber set visually to be flush with fender lips
ALTERNATE WHEEL SETUP:
Wheel Brand/model/Spec(size/width/offset): O.Z. Racing Crono 17x7, et42 ($20)
Drop and Alignment Specs: Front & Rear right around 23". Camber and toe not known with this setup (I need camber plates for the front).
Tire Brand/model/Spec: Falken Azenis 215/40R17 Front & Rear
Wheel Brand/model/Spec(size/width/offset): OZ Racing/Focus RS/18x8 et42
Tire Brand/model/Spec: sumitomo/htr+/225/35/18
Suspension parts: bilstein pss9 coilovers, dominant engineering rear lower control arms
Drop(fender heights are acceptable) and alignment spec (camber and TOE!): fender heights: 23 3/16" F, 22 3/4" R, camber -2.0/-2.5 on all four corners/toe set at 0
Wheel Brand/model/Spec(size/width/offset): schmidt 16x7.5 f 16x9 r et35
Tire Brand/model/Spec: yoko s drive
Suspension parts: D2 Coilovers
Drop(fender heights are acceptable) and alignment spec:unknown / unknown
IMG_0188 by oriskazuki, on Flickr
Wheel Brand/model/Spec(size/width/offset): 17x7.5 Rota Slipstreams et40
Tire Brand/model/Spec: Cooper all seasons 215/45/17
Suspension parts: DGR Coilovers fender heights are 23.25" front and 23.5" rear
Discussion starter · #34 ·
Ok guys, I don't mean to be a dick but the point of this thread is to post your setups WITH specs to show people what different drops/alignments/widths/offsets/TIRE SIZES look like... This thread is not just another place to post your cars.
Please do not post your car if you haven't atleast spent the 5mins of time to get fender heights.
Alignment and all the other specs are not "optional" either, and again, the point of this thread is to share those specs!
Thanks
hi guy's!
very nice forum! all about ford! i like!
srry for the bad language..i'm from Belgium so...
I drive a Ford Focus MK1 (facelift)
suspension: rokker..adjusted for going extra low
wheels: DZ Exclusive (1) front rim's: 7.5j and back: 9.0j and they are 16inch
tires: 195/40/16 all around
camber? just by slamming it..don't know how many degrees it is .. srry!
and here are soms pic's. let me know what you think of it...
and here are some every day ride height pictures..
(girlfriend drove it a little..srry for crappy gsm pic's.)
and a little tyre stretch pic.
grtz
Focuskn
Wheel Brand/model/Spec(size/width/offset): Team Dymanic Pro Race 1.2 17x7 et 45mm
Tire Brand/model/Spec: Direzza Sport Z1 Star Spec 225/45/17
Suspension parts: Front: KW VR2, LCR Race Camber Plates Rear: FK shocks, H&R Race Springs (-2 coils), SPC Camber Blades
Drop(fender heights are acceptable) and alignment spec (camber and TOE!): Front: 23 1/2in, 3 degrees, 0 toe Rear: 24in, 2.25 degrees, 0 toe
Land Rover HSE 19x9 et53 19mm adapters front, 23mm adapters rear Final et of 34mm Front, and 30mm Rear
(some Chinese brand ) 215/35/19
Suspension parts:
CXRacing Mazda3 coilovers Frankenstein'd, SPC camber arms (Set to stock length, no extra camber)
22.5"Front 22" rear
Wheel Brand/model/Spec(size/width/offset): Sportmaxx 050 ET38 Before 13MM spacers from/25MM spacers Rear Final ET 25/12
Tire Brand/model/Spec: Falken 512s -205/40/17
Suspension parts: KSport Coilovers, Massive Toe Arms, SPC Camber Arms
Fender heights are 22" all around.
Camber:
FL= 2.4 FR= 2.9. RL= 3.5 RR= 3.5.
All toe set to 0 degrees.
Wheel Brand/model/Spec(size/width/offset): ICW 18x7.5" et37
Tire Brand/model/Spec: BFG DZ101 215/35/18
Suspension parts:Ford Racing (AKA KW V1) coil overs. SPC rear camber bolts
Drop(fender heights are acceptable) and alignment spec (camber and TOE!): 22.75" all around. Toe: 0* on all four Camber: Natural Front, Slightly adjusted in the rear to clear the fenders.
Wheel Brand/model/Spec(size/width/offset): 17X7.5 Rota Slipstreams
Tire Brand/model/Spec:Federal 215,45,17
Drop and alignment spec: N/A
Freshly dropped as of Saturday 5/12/12. Sp will get better pictures soon!
21 - 40 of 66 Posts
